D PETCOCK'S
GARY LAMAR
01-24-2002 18:31:11
MY 1942 D PARTS BOOK SHOWS A PETCOCK WITH A CUP ON IT,WHY? ALSO IS THIS THE CORRECT PETCOCK THAT SHOULD BE ON THE 1942 D? THE ONES I HAVE ARE LIKE ON A B AND ANGLE OUT TOWARDS MY LEG,THUS GIVING MYSELF A WET LEG!! ;-) GARY
donwiscI
01-25-2002 08:03:15
 Re: D PETCOCK'S in reply to GARY LAMAR, 01-24-2002 18:31:11
I know what you mean about getting a wet leg on the B style petcocks.
I would suggest you replace them with a couple of gas shutoff valves, 6.00ea from ACE, youn can add fittings to direct them any way you want and they dont leak. Save the brass ones for show.
Brandon
01-24-2002 22:38:48
The petcock with the bowl would be correct, as far as I know. They were used to prime the engine with gas in cold weather, or if the tractor just didn't want to start.
Your petcocks will work just fine for releasing the pressure-you just can't prime the engine. Many Ds have them, and you shouldn't really need to prime if the engine/carb are in good shape.
Good luck,
Brandon
