Power steering pump bushing
Ben.So.Tex
01-24-2002 17:16:20
What is a good way to remove the the bushing in the pump? I can drive one out but the other are recest in the pump.Can I pick at them with a chisel and peel them out. I am running alittle scared. I do not want to damage the pump..
Clooney
01-24-2002 17:24:24
 Re: Power steering pump bushing in reply to Ben.So.Tex, 01-24-2002 17:16:20
Ben, the way I usually pull blind bushings is by tapping with an appropriate sized tap then thread a bolt in the bushing & either use a pipe or spacer & tighten the bolt to pull the bushing or clamp a pair of vise grips on the tap or bolt & tap it in the outward direction with a hammer.
