J.d. 4030
d. partin
01-24-2002 14:03:03
this tractor will not start off of the key and the guages do not work .occasionly after hitting a bump guages will work and tractor will start .also batteries drain quickly.any ideas on a fix or info on a wiring diagram.would be greatly appreciated.could this be a ground problem???
Gord
01-25-2002 17:32:47
 Re: j.d. 4030 in reply to d. partin, 01-24-2002 14:03:03
The problem sounds like the power wire from the top terminal on the starter has lost connection to the circuit breakers. Follow the large red wire through the fire wall above the starter. That wire should go under the dash on the LH side. Take the cowling off from around the dash. Check the front set of breakers to see if power is present at the buss bar that connects all of the circuit breakers together. Then check for power at the wire connections to the breakers for 12v power. If power is present at all the breakers then you need to check at the key switch for 12v power on the battery terminal. Power can be lost by loose terminals on the breakers. The batteries going dead could be caused by no power from the key switch to the #1 terminal on the alternator. Both small wire terminals on the alternator should have power when the key is turned on. #1 should have 2-9 volts and #2 should have 12 volts. Let me know what you find.
d. partin
01-29-2002 17:06:46
 Re: Re: j.d. 4030 in reply to Gord, 01-25-2002 17:32:47
would anyone have a wiring diagram for a 1976 4030 i have traced wires from starter around to ign. switch.12v power is present at switch but when switch is turned to start position voltage drops to zero.
