JD R electric starter
smoker
01-23-2002 14:37:27
Does any one know if a conversion was made for the R so that the pony could be gotten rid of? I have heard that the pony is a lot of trouble and very expensive to rebuild.
B.Webster
06-21-2005 11:08:32
 Re: JD R electric starter in reply to smoker , 01-23-2002 14:37:27
As far as i know nobody has built an electric convertion because the ring gear teeth are too large . I am working on this very thing and hope to have a convertion available within a few months >>Bob from Webster Mechanical
kkreek
01-24-2002 12:07:51
Just rebuilt the pony on my R. Around $300 including turning the crank. If you wish to replace the pony with an electric start, you can probably use the starter off a 4430. That's what I used on my 70D which had already had the pony missing when I bought the tractor. But the starter alone cost over $300. I built the mount for the starter. If you wish more info, email me. kkreek
G Taylor
01-23-2002 18:42:00
We never abused our pup engines with cold starts,lack of service or engaging the diesel with the compression & fuel already underway. They usually work & required only schedualed maintence for 30 years before a modestly priced overhaul.
Denny Frisk
01-23-2002 14:54:15
The "R" is the only tractor deere made with only a 2-cyl pony motor... it's kinda under-powered for starting in cold weather... You could maybe look at some elec. start 730 diesel parts.... Maybe check a salvage yard??
