Fenders??
Tyler Buchheit
01-23-2002 06:07:10
I have a 1957 JD 720 gas. I'm wondering what fenders were available for the tractor. Ive seen them with the little half-moon fenders. But, im wondering about the more modern style ones with lights in them. Input would be appreciated.
Donwisc
01-23-2002 09:36:18
 Re: Fenders?? in reply to Tyler Buchheit, 01-23-2002 06:07:10
The flat top fenders did not start until the 30 series was introduced but that should not stop you from putting them on as they will fit the 20 series also.These same fenders were used on the new generation 3010s also but these had the hand holes on both fenders whereas the two cyl ones only hand the hand hole on the left side.Good luck in finding a set, any thing around 400.00 or less will be a bargain.
Allen
01-23-2002 16:40:50
 Re: Re: Fenders?? in reply to Donwisc, 01-23-2002 09:36:18
you can buy new ones from any JD dealer, fenders come from our A & I division, they do come with hand holes in each, I have customers just weld one hand hole up. they also have the cast brackets, this works out cheaper unless you are real lucky to fine org. ones. up here in Ont. orginal ones are hard to fine happy hunting Allen
