Carburetor Repair/Rebuild
Stan - Florida
01-22-2002 13:02:28
I have a '41 B that needs some carb work, and I'm looking for opinions on carburetor rebuilders. The three I've talked with so far are Robert's Carburetor Repair, Denny's Carb Shop and Burrey Carburetor Service.
Has anyone had experience with these folks?
Thanks in advance,
Stan
Stan - Florida
01-23-2002 17:00:08
 Re: Carburetor Repair/Rebuild in reply to Stan - Florida, 01-22-2002 13:02:28
Thanks to all for the replies and the advice.
This reminds me of the discussions I had with my buddy when we were restoring the beast in the first place. He thought the fan blades should be yellow, but I thought green. We argued about if for a long time.
The first time I took it to a show I found a note taped to it saying, "I still think the fan should be the other color". Didn't matter which I did, did it?
Again, thanks for the thoughts.
Stan
Eugene swia
01-23-2002 04:15:54
I could give you Robert's video. Then you could learn how to use a little piece of wood to hold carb as you work on it. Also no need to clean passage way's out, but make d@@@n sure you sand blast and a nice bright paint job. Sarcasm, you bet. Fix it your self, gasket set is 7or8 bucks.
Deere Puller
01-22-2002 15:46:09
Stan - If you are willing to 'learn', Deere carbs aren't that difficult to navigate, unless the stems are broken. For tools, you will need an impact screwdriver (most times you just need the leverage that the fat, heavy handle can provide, a good set of torch-tip cleaners and a $5.00 slide hammer to remove the nozzle. Both Roberts and Burrey are fairly expensive(good quality), with Roberts being terribly slow. I'd personally stay away from Denny's - I've fixed a few 'professionally-rebuilt' carbs for friends that have either bought outright or sent theirs in for rebuild.
If you would like a blow-by-blow of how to perform the job, send me an e-mail & I'll be happy to oblige.
Mike
01-22-2002 14:43:44
if ya have any patience do it youself. A bucket of carb cleaner and a kit will run you 30$ The only special tool you need is an impact screwdriver to remove the pin holding the float. PATIENCE is the key.
RHW
01-22-2002 14:30:25
Stan
I've dealt with Burrey and Roberts and neither are cheap. Burrey was much faster, but you'll be hard pressed to beat Robert's for quality. My carb looked like brand new when it came back from Robert's and worked perfectly - 14 weeks later.
RHW
Mark-Florida
01-22-2002 13:57:40
I ordered a kit from Roberts and talked to him very helpfull and quick with shipping .By the way, Stan do you go to any tractor shows There is a tractor show and pull at the citrus county fair grounds this weekend i'm going to check out . I went to the Florida Flywheelers at Ft. Meade swap meet last week end that place is pretty big .
