CrankShaft/CamShaft Line Up
Henry J
01-22-2002 09:53:10
I am starting to assemble a Model 'B' basket case. The camshaft gear has a punch mark on one of the teeth, but the corresponding gear on the crank does not have a mark on any of the teeth. I am sure the gear on the cam was set at the factory. How do I set the crank relative to the cam so that the valves operate consistent with piston movement?
WTW
01-22-2002 11:08:46
 Re: CrankShaft/CamShaft Line Up in reply to Henry J, 01-22-2002 09:53:10
Hennery, The cam gear on your B has timing marks on both sides of it. The mark on the outside is to time the governor gear to the cam. The mark on the inside is to time the crankshaft to the cam. To align the cam mark to the crank mark you have to view them from the inside looking down through the crankcase cover opening. Hope this is the information you needed. Dave W.
ChuckW
01-22-2002 10:08:18
don't believe you're looking close enough, there should be like a pointed v mark on the crank.
