730D stuck in gear
david
01-22-2002 08:55:22
Was wondering if this was a common problem or how to fix. It appears to be stuck in the lower right corner (close to 2nd gear I think). Has anyone had this problem before?
CLW
01-22-2002 13:45:49
 Re: 730D stuck in gear in reply to david, 01-22-2002 08:55:22
David, You might try puting it back in the gear slot you were in last if you can remember what it was. Then try moving a short distance, then try again. If it don't want to move DON'T force it, you could be in two gears at the same time.
CLW
nathaniel watts
01-22-2002 09:36:54
it appears your shifter is knocked out of the slot. remove the shifter assemly and you should see that the slots are not aligned. move the tractor to a level surface and realign the shifter forks. then replace the cover being carefull to get the stick in the shifters. hope this helps.
