Early Styled B Power Lift Gaskets
Henry J
01-21-2002 18:28:11
There have been several posts about replacing the leather cup gasket in a Power Lift cylinder. Can someone who has done this recently for an early styled 'B' confirmed that the parts required are: B2800R 'Teated Paper washer' and B2799R 'U Cup Packing'? If not please specify the correct part number for the 'Leather' in the Power Lift cylinder.
Rod
01-21-2002 19:07:56
 Re: Early Styled B Power Lift Gaskets in reply to Henry J, 01-21-2002 18:28:11
According to my B parts catlog ( PC-330 ) those are the correct numbers and discriptions.
walt f
01-21-2002 19:36:49
 Re: Re: Early Styled B Power Lift Gaskets in reply to Rod, 01-21-2002 19:07:56
walt f
01-21-2002 19:32:56
do you have piston b 468 r (sub for ab 4211 r) or piston ab 4212 r (sub for b2798r)?
Henry J
01-22-2002 19:20:39
 Re: Re: Re: Early Styled B Power Lift Gaskets in reply to walt f, 01-21-2002 19:32:56
Walt,
I assume it is it is an AB4212R bcause looking at the top of piston cup retainer, I see a B1146R. Perhaps then I need a B1145R leather piston cup. If this is true, it looks like the 43B was bastardized with a piston from a late styled assembly. Do you concur?
