John Deere A pistons????
Will P
01-20-2002 18:45:58
My 43 A had a cracked block. So I got a junkyard one. Was going to leave the pistons. But they looked different. They are cast iron. They are John Deere. The part number is: A 3530 R . They are about 1/4" taller than my pistons I pulled out of my 43 A. I heard about a Gasoline conversion kit from Deere in the 50's. Are these those pistons? Are they Rare? Thanks for the help.
Will P
Mike H
01-21-2002 18:03:10
 Re: John Deere A pistons???? in reply to Will P, 01-20-2002 18:45:58
Yes, those are the gas conversion pistons they can out of a AA4251R kit that can w/rings,pins,pistons and intake and exhaust gas manifold.I have 3 such Kits NOS in the box.And am currently trying the install in a 37 A,Having a little trouble with the wrist pin size.The early has 1.605 and these out of this kit are 1.751
Will P
01-21-2002 21:05:20
 Re: Re: John Deere A pistons???? in reply to Mike H, 01-21-2002 18:03:10
When I went to Deere for rings, They tried to give me 3/16" rings. My pistons take 1/4" rings. There was a note at the bottom of the page that stated that the early run of pistons took the 1/4" rings. Don't know what size the wrist pin is. But probably what ever the rods are out of. It had no serial number on the tractor that I got them out of. But it was an electric start slant dash 6 speed. 41-47. I need a manifold. I went and got an all fuel manifold for it (the one on was rotted) before I got the pistons. Now I want to hot rod it to about 40-45 hp. How much for the kit? I would give you my pistons and rings and pins and $$$ for the whole kit? Or would you just sell me a manifold? Thanks for the help. Good luck with your 37.
Will P in Wisconsin
Frank
01-20-2002 19:29:39
Will:
My parts CD shows A 3530 R as the gasoline piston (standard size) used in "A"'s between S/n 488,000 - 583,999.
I believe the 584,000-UP was the "New"styled years, with the battery box seat, so these pistons are probably from a re-fit kit.
Frank
walt f
01-21-2002 15:50:00
 Re: Re: John Deere A pistons???? in reply to Frank, 01-20-2002 19:29:39
my 1951 a parts book says 488000-583999 piston, two a3530r, with pins and rings, 3/16"(gasoline type engine) (sub. for aa4249r)----- -- this would mean that it is standard bore (hasn't been bored yet). you could find a good set of factory .045 oversize, if you need to. or you could keep an eye out for a set in the near future, if a set is available at a good price for later. you wouldn't have to use a aftermarket set.
