3020....
john2520-3020
01-20-2002 15:41:55
i need help on my 3020....i was useing it to blade snow today and it went to missing...stopped cleaned plugs and played around on it for about 2 more minutes then it went to missing again...so i stopped checked and cleaned plugs and went to start it...nothing....it is getting fuel to carb. and the spark seems to be a good hot spark, so what else could it be? thanks for the help..
john
Hugh MacKay
01-22-2002 06:01:28
 Re: 3020.... in reply to john2520-3020, 01-20-2002 15:41:55
I was having same problem with a Farmall. Discovered if I removed distributer cap wiped with paper towel, worked fine for twenty minutes,same thing again. Went to dealer yesterday, he sold six caps in the last three days and didn't have one. Same thing at two auto parts stores. We have been getting a lot storms with freezing and thawing and back again. Car and pickup doors froze shut,etc. I picked up a can at NAPA, called moisture retardent, sprayed in on, works well in short term anyway. I hope it will stay until I get a new cap.
BIG JOHN
01-21-2002 04:10:24
Check for moisture under the cap, this is common on gas engines. poor points and old wires will also do this under some load, may idle nice. unless your blowing snow I don't think its the carb, but I may be wrong-it's easy to check.
JOHN
Zig
01-20-2002 19:14:49
John Could you have a air restriction of some kind or ice in your carb?
