'51 B JD
JOEL
01-20-2002 08:39:58
I NEEDED A CRANK, FOUND ONE TURNED TO .020 INDICATING I WILL HAVE TO HAVE THE RODS REBABITED. THE REPAIR SHOP INDICATES I DONT OR THIS MODEL DID NOT HAVE BABIT RODS - ANY INFO WILL HELP - THE SER # IS 201000 UP -
Will-Texas
01-20-2002 11:15:37
 Re: '51 B JD in reply to JOEL, 01-20-2002 08:39:58
Late JD "B"s came with insert type rod bearings. Your tractor should be one of these. The parts book doesn't give the serial number when this changed from the babbit type. Your tractor should have these. My 260,xxx "B" has the insert type. These bearings are listed in .020 in part cat. PC330. You would need to check with a JD dealer to see. If you, by chance, have babbit rods and they are in good shape, you may be able to remove enough shims to make them work. I'm not sure about this.
Bob Weber
01-20-2002 16:35:11
 Re: Re: '51 B JD in reply to Will-Texas, 01-20-2002 11:15:37
My B, # 298311, has babbit instead of inserts. I'd be interested in knowing when they changed to inserts.
