4630 Block Heater Glowplugs Cold Starting
Paul Butler
12-03-2003 05:49:49
I have a 4630 that is obviously getting harder to start as the temp drops. I have 2 questions:
1) Does it help to leave the key on for a minute or so before cranking? (We used to have to do that with an old Diesel truck to get it to start).
2) I plugged the block heater in for 2 days but it was still cold to the touch-at least on the outside. I have never used it and assume it is bad. Can those be replaced?
3) That little frame that holds the either can is missing on my ether injector. I hate to buy the whole thing (about $80) when I just need that wire frame and tensioner bolt at the bottom. Until I find one at salvage or get time to make one can I just squirt some ether down the air intake or open the canister filter and spray some in there?
david val
12-03-2003 06:55:50
 Re: 4630 Block Heater Glowplugs Cold Starting in reply to Paul Butler, 12-03-2003 05:49:49
1) leaving the switch open will not help in starting the engine.
2) block heater is replaceble, there are two types. have your engine serial # availible when ordering.
3) you can apply ether directly, but the quantity will not be contolled as with the small orifice in the original setting. you should spray SMALL shots of ether WHILE the engine is cranking.
david
thurlow
12-03-2003 08:10:09
 Re: Re: 4630 Block Heater Glowplugs Cold Startin in reply to david val, 12-03-2003 06:55:50
These questions about the use of ether show up almost every week; most replies are basically the same as yours about the desired method, but..... with the engine turning over, I can never get the right amount injected and find it very easy to "lock" the engine up. What has worked better for me (for 40 plus years) is a "controlled" shot before beginning cranking. Takes more ether, but it's much easier to gauge how much to use (at least for me). Have followed your's, G-Man's, Brokenwrench's and (a few)other's posts for a long time and find very little to disagree with..... ....
