730 and a Howse shredder question...
mike-nm
10-15-2003 19:36:23
Can a 730 handle a 12 foot howse shedder? or is this too much for the tractor, I saw a howse shedder coming up for auction and was just wondering. Thanks-mike in new mexico ps- the shedder has a 540 pto and a hydraulic cylinder that adjust the cutting height. the tractor would just have to pull it and the pto would have to turn the 3 gear boxes.
Mark
10-16-2003 17:31:11
 Re: 730 and a Howse shredder question... in reply to mike-nm, 10-15-2003 19:36:23
Should pull it with no problem,assuming you are not trying to mow stuff taller than the exhaust pipe on the tractor. I have pulled a 15' woods batwing mowing pasture with a 730 D. Make sure the mower is set properly with the front cutting slightly lower than the rear,so you are not cutting the same grass twice.
mike-nm--- Thanks
10-16-2003 18:06:48
 Re: Re: 730 and a Howse shredder question... in reply to Mark, 10-16-2003 17:31:11
Sounds good maybe I'll have some luck at the auction.
