Coolant for John Deer 3020
stoney
01-19-2002 11:10:19
Recently I added a tank heater to a 3020 and the coolant appeared to be straight antifreeze. When I replaced it I mixed it 50/50 with distilled water. Is there a reason for running straight antifreeze in 3020?
Deere Puller
01-19-2002 13:12:32
 Re: coolant for John Deer 3020 in reply to stoney, 01-19-2002 11:10:19
No, especially since straight antifreeze does not cool as well as the 50/50 mix. Be sure to add an appropriate amount of coolant conditioner, available at your local Deere dealer, to protect the o-rings sealing your sleeves. It also helps prevent cavitation, but since you used distilled water, you've solved nearly 90% of the problem already.
