2355 lift arm leak?
Wayne
12-02-2003 23:52:38
I have a 2355 that leaks hydraulic fluid from the rear end where the lift arms attach. I have taken the tractor to the local dealer and after $500. it still leaks and the 90 day warranty has expired. It leaks where the lower arms attach to the shaft that runs thru the rear end. I have replaced the rubber seals that the online parts link shows. It seems to smash the seals and I don't want to change the shaft bushing. The dealer said they did replace the bushing and renew all those parts. Any help to get the leak stopped? Thank you, Wayne
david val
12-03-2003 07:07:52
 Re: 2355 lift arm leak? in reply to Wayne, 12-02-2003 23:52:38
make sure that the cavities for the sealing rings are clean. lap the shaft end that goes in first to get a hige finish with long taper. make sore the edges if the cross hole are beveled and very smooth. lubricte sels with grease and immerse shaft in oil. insert shaft carefully eeith a slight twisting.
david
