JD 50 stuck in gear
Matthew
10-15-2003 19:24:10
We are currently in the process of starting a restoration on our 1954 John Deere model 50 tractor. Right now it is on the edge of a field where it was parked(in working condition) over 25 years or so a go. At the time it was mounted under a cotton picker but the picker was moved about three years ago. We are wanting to transport to our shop but are unable to because the engine is locked up in gear and the tractor will not move an inch. Of course the tires are dry rotted to the ground and this doesn't help. We need to be able to put it in neutral so that we can get the rollback to winch it up and haul it off. The clutch also seems to be stuck. I was just wondering if anyone else has run into this stuck in gear problem and what my options were as far as getting it to move. Thanks for the help. It is greatly appreciated!
john
10-16-2003 16:58:16
 Re: JD 50 stuck in gear in reply to Matthew, 10-15-2003 19:24:10
I ran into the same problem on a JD model b. I took the clutch apart, found no problems, ended up being the bull gears in the rear end were froze up from condensation. Jack up the tractor to try to rock the wheels back and forth.
Chuck W
10-16-2003 14:03:37
my suggestion would be to remove the clutch assy so that this would be know to be free. Then you can load or move the tractor around, wheather in gear or not.....
Bruce L
10-16-2003 12:47:46
Having sat for so long, the transmission could have filled up with water from condensation. I have a fresh appreciation for this having just rebuilt the tranny on my JD50. All the bearings were corroded to some extent, some fairly severly. Your shifter shafts or the particular gear that it is in could be stuck from sliding on their shaft by corrosion I suppose. I don't think clutch problems would prevent you from shifing into neutral if it is sitting on level ground and there is no pressure on the gears. What gear is it stuck in?
Matthew
10-16-2003 14:30:02
 Re: Re: JD 50 stuck in gear in reply to Bruce L, 10-16-2003 12:47:46
Let me get back with you on that please.
Dave K (SWFLA)
10-16-2003 08:41:18
Might be your clutch is stuck engaged and if the engine is frozen and the tranny in gear she won't go. Pull the cover off the clutch and see what you got in there. Pull the tranny cover and shifter fork off and see if you can line all the collars up to center (neutral).
Dave
rman
10-15-2003 19:52:43
matt make sure that brakes on drums are not stuck this is common problem you may have to remove brake asy from housing bet this will let you rock tractor to get out of gear rman
