520 Torque Specifications????
Tyler-MO
12-02-2003 21:09:10
Hi again,
I'm finally ready to re-install my block. I've got a new gasket and cleaned the surfaces per. my 720 service manual...my question is how much to torque the block to main case studs to??
Any help is greatly appreciated. Tyler
ChuckW
12-03-2003 08:48:59
 Re: 520 Torque Specifications???? in reply to Tyler-MO, 12-02-2003 21:09:10
F.I.T. wondered what the offset and additional reach would do to the torque value accuracy. On the case bolts I don't think it matters just as long a you get a good even torque, as I recall the combination box end from JD was used on the wheels and bolts such as this.
F-I-T
12-03-2003 10:07:58
 Re: Re: 520 Torque Specifications???? in reply to ChuckW, 12-03-2003 08:48:59
Chuck:
I don't have it handy, and I always forget the length, but I measure it and factor that in to the total lever. For exapmle, if the standard torque wrench handle was 30" long, and the adapter is 3" center of rotation to center of rotation, I reduce my torque value by 10%.
Frank
I mis-spoke.....F-I-T
12-03-2003 10:14:36
 Re: Re: Re: 520 Torque Specifications???? in reply to F-I-T, 12-03-2003 10:07:58
Chuck:
I typed faster than I was thinking!
REALLY, what I do, is to say I now have a lever 10% longer, so I have a 110% long lever, so I divide the intended torque value by 1.1
That's the right way.
ChuckW
12-03-2003 05:04:52
those torque specs are probably correct, however the problem will be getting a torque wrench to work in this space, when you are being given a 275 reading this generally means as much as you can torque by hand. I've always had to use box end wrenches for this purpose.
F-I-T
12-03-2003 07:59:51
 Re: Re: 520 Torque Specifications???? in reply to ChuckW, 12-03-2003 05:04:52
third party image
I mig welded this adapter for my 400 ft-lb torque wrench out of a cut off box end wrench and a 3/4" to 1/2" converter that I had twisted off.
It really works well on block to case bolts, and it lets me get in to the flywheel bolts better as well. Sorry the picturs is a bit fuzzy.
Frank
Duane Larson
12-02-2003 21:22:18
Tyler,
Oops!! I gave you the torque for a 720 and you asked about your 520 - ignore the first post!! The cylinder block to main case for the 520 is 167 ft-lbs. The head nuts torque to 104 ft-lbs.
Tyler-MO
12-02-2003 21:26:23
 Re: Re: 520 Torque Specifications???? in reply to Duane Larson, 12-02-2003 21:22:18
Thanks a bunch.....
you wouldn't by chance have the torque specs for the rod cap bolts or any other relevant information pertaining to my 520 reassembly project?? Thanks
Tyler
Duane Larson
12-03-2003 06:20:02
 Re: Re: Re: 520 Torque Specifications???? in reply to Tyler-MO, 12-02-2003 21:26:23
Tyler,
Yes I do, the FSB gives two pages of torque values. If you email me at [email protected] I will scan and email them to you.
Duane Larson
12-02-2003 21:19:13
Tyler,
According to JD Field Service Bulletin 247 (November 1956) the cylinder to main case torque is 275 ft-lbs for both gas and diesel (and is the same as the cylinder head nuts).
