730 Power sterring sucking air ?
Ben.So.Tex
01-17-2002 17:29:27
My 730 power sterring will blow out fluid when I open the dip stick on top of the peadastal.Where can it be sucking the air from ? I have notice oil seapage on the pump behind the fan, Could it be sucking the air through the loose gasket ? The peadastal dose not have any sign of oil leaks. I did cleaned the vent in the tube last week. thank you.. BEN
KEVIN
01-18-2002 11:36:20
 Re: 730 Power sterring sucking air ? in reply to Ben.So.Tex, 01-17-2002 17:29:27
MY 720 WAS DOING THE SAME THING. THE SEALS IN THE POWER UNIT IN THE PEDASTAL WAS SHOT. THE UPPER SEALWAS BYPASSING PRESSURIZING THE WHOLE UNIT. NEW ORINGS FIXED IT
KEVIN
Clooney
01-17-2002 18:23:12
~Ben, the usual place the 2 cylinder p/s sucks air is the pump seal(s).
Ben.So.Tex
01-18-2002 03:51:39
 Re: Re: 730 Power sterring sucking air ? in reply to Clooney, 01-17-2002 18:23:12
Thanks.Clooney.I have to replace the radaitor so now is a good time to get after it.
