Clooney
01-18-2002 14:30:03
Re: Re: Re: Re: Re: Re: Re: Re: Distributor question? in reply to G Taylor , 01-18-2002 12:24:51
Glen, are you sure your system is obd-2, compliant? That system didn't go into production until much later. I didn't think we brought obd-2 ahead for Canada. (but sometimes Canadian laws force different timing on emission compliance so it could be possible) ~Does your vehicle have ABS, or RWAL or none?. I looked a can't find a 94 manual in my old manual collection but do have a wire print of a 93 Blazer on my computer. I haven't worked on the old style TCC system in over 10 years (am working on 2004-2006 stuff now) so will have to find a wire print or pinout before commenting conclusively on your system as I don't want to confuse you with incorrect information. ~Coolant temp,,, vehicle speed,,, tps,,, engine load/vs/RPM, (map signal-if yours has a map)or could use a combination of map & maf (mass airflow) or would just use maf if no map sensor,,, ABS (if equipped) are some of the PCM input signals that are used to tell the PCM when to ground the wire from the TCC lock up solenoid in the trans. The other end of the TCC lock-up solenoid is powered by a 12 volt source usually from a separate brake pedal switch than the brake lights (probably a purple wire). On some of the later obd-2 systems the brake input goes directly to the PCM & the PCM drops the ground side of the circuit for ice & ABS wheel lock up. ~If your problem wasn't so speed sensitive I would suspect the terminals at the trans connector as we had plenty of problems with those maintaining connection (especially after being unplugged a few times) the best way to test those is with a new male & female terminal by pushing onto the existing terminals in the trans & harness connector to see if you can feel a slight drag as the terminal is pushed in & pulled out. ~The trans has a sump temp sensor that could be causing a problem, if you are using an external trans cooler make sure it is in the trans out let line so the oil goes back through the radiator cooler before re-entering the trans (the ideal trans temp is the same as eng temp) or better yet by-pass it for winter use. ~A scan tool such as a TEC-2 or even a TEC-1 (if non obd-2) is the best approach as it will let you manually lock the trans TCC & you can monitor all the PCM input signals & even 12 volt brake s/w on/off. ~I have a software package on my laptop to monitor all PCM, BCM signals & even flash a new cal to the newer programmable PCM & BCM's, I don't think it will work on the old PCM's though & I haven't ever tried it because my cable won't hook to the old style ALDL connector. ~If you have the old non-obd-2 ALDL connector under your dash (drivers side) see if it has a tan/black wire in cavity "G" if so that is your TCC monitor wire for the scan tool & can be used with a (12 volt powered) light bulb to see if the PCM is actually grounding the TCC solenoid when the parameters are met for lock-up. ~If I can come up with a manual or wire pin-out I will be able to give you a step by step diagnosis to eliminate all but the trans internals & even some of those can be fooled externally because some are bypassed in 3rd gear & on the shift. ~If you suspect a cooling (over cooling) put cardboard in front of the cooler & radiator to see if higher rad & cooler temps will solve your intermittent problem. ~If you still can't find the problem after you look in your manual & eliminate the trans oil temp as the cause, E-Mail me & I will lend my old TEC-1 to you (it won't read on obd-2 though) & all it will cost is the shipping to & from Michigan.
