J.D. stationary horse and half model E
farmie46
10-15-2003 19:17:10
I can't get my engine to fire had my mag charged. ignitior looks good. test light will lite when turning motor over when just hooked to lite but will not when hooked to ignitor. ignitor is shut when not triped. should it be open? Would my mag be weak? It just will lite my 12 volt test lite. Any info would be helpful thanks.
farmie 46
10-16-2003 11:51:34
 Re: J.D. stationary horse and half model E in reply to farmie46, 10-15-2003 19:17:10
I want to thank Mr. clooney and the web site here. I didn't know it even was here till I was looking last nite. I hooked a coil up to the motor and was shocked at how easy the motor started. First time the ignitor snaped it was off and running. I took the wire off the coil while it was running and touched it to the mag. but it would not stay running. Ithen hooked my test lite to mag and it was brite. So I am guessing it must be a ignitor problem. I took it out and used so emery cloth on the points and made sure they were closed all the way but still will not work with the mag.
Clooney
10-16-2003 15:26:01
 Re: Re: J.D. stationary horse and half model E in reply to farmie 46 , 10-16-2003 11:51:34
farmie 46, you must have received the E-Mail on setting up the battery/coil in place of the mag?....
~It sure sounds like your mag is slightly out of time. That mag has to be timed about perfect to make that engine run.
~It sounds like your mag is peaking it's output after the ignitor is snapping.
~Try setting the ignitor to snap after the spark mark on the flywheel passes the valve push rod by about 3/4"-1". If that helps it run on the mag your mag is out of time.
~Maybe your ignitor timing is just set incorrectly [it should snap as the spark mark on the flywheel is even with the valve push rod].
~I doubt your problem is the ignitor if it runs good on the battery/coil set up.
~If you have a voltmeter, use the info in the first post to check for peak mag voltage as the spark mark lines & the ignitor snaps. My guess is you will find either the mag is out of time slightly or the ignitor is snapping earlier than the spark mark is lining up..... Again: that mag MUST be timed almost perfectly to make that engine run. Because it ran on that mag when you got it & not now I would believe the ignitor timing has moved slightly from where it was,,, OR, the front internal mag shaft has spun slightly in it's mounting plate..... .
[email protected]
Clooney
10-16-2003 03:53:07
farmie46, you ask....
"Test light will lite when turning motor over when just hooked to lite but will not when hooked to ignitor".....Answ, That's normal, the ignitor shunts most of the little current that�s there is to ground.
~"Ignitor is shut when not triped. should it be open?".....Answ, That's correct on a low tension mag system. The only time you want it to stay open prior to the sparking point is if you are [continually] using an ignition coil & battery.
~"Would my mag be weak?".....Answ, It doesn't sound like it. If it will light up a 12 volt test light [even a little] it is probably good. I always use a 6 volt bulb as a test so if it will light a 12 volt light it is making plenty of power. Remember that is a LOW TENSION mag & doesn't produce enough power to jump a spark gap.
~It just will light my 12 volt test light. Any info would be helpful thanks"..... Answ, That sounds about right.
~On the reason it won't run?�.The first thing to check is the fuel system check valve in the fuel tank.. THAT IS THE NUMBER ONE REASON those small JD 1.5 hp engines act up or won�t start. IT MUST BE ABLE TO PULL FUEL past that check valve to run. If you hold your thumb over the mixer opening while cranking & it pulls fuel up & floods out the bottom of the mixer you probably don�t have a fuel problem. If it won�t, then you have a fuel issue [usually that darn check valve]..
~Next on the list would be correctly timing that mag.. It MUST be timed perfectly or that pathetic little mag won�t produce enough spark to make an ant jump�.To do that there is a L/H & R/H small push button on the back cover of the mag that can be held in until the inner depression lines up [falls in the hole] at spark position. Problem is, I can�t remember which one you use as I never time those mags with those buttons.
~I always time those rotary mags using a volt meter�I just install a voltmeter between the mag output terminal & ground [with the ignitor wire disconnected], then slowly turn the engine in the starting direction & watch the voltmeter needle [I use a analog volt meter], the ignitor should snap JUST AS, or JUST SLIGHTLY AFTER the voltmeter shows peak voltage. THAT SETTING IS EXTREAMLY CRITICAL for a good spark� You don�t want the ignitor to snap before max voltage is reached [just as] is the best with [just slightly after being ok].
~Before setting the mag timing be sure the valve push rod is adjusted correctly & the SPARK mark on the flywheel is just lining up with the push rod as the ignitor snaps.
~If the mag is set correctly, & it is getting fuel, your problem could be worn parts in the ignitor. It must open exactly as it snaps. If it has worn points or the ignitor housing is worn the points will move sideways as they open & what little spark you had will dissipate into the unknown.
~My suggestion would be to try to get it to run on the mag but don�t spend a lot of time doing that� Use a 12 volt battery & the primary windings on an old car ignition coil to make it start & run to begin with. Then once you have it starting & running good switch back to the mag & work with that to get it to operate correctly�There are so many things that can make those old Deere engines act up & the mag is just one of them. By operating it on a battery & coil you can eliminate one of the problems right off until you get the others sorted out.
~If you want to run it on a battery & coil just E-Mail for directions [it�s real easy to do] .
~As Jake said those Deere mags tend to swell the mag armature ends & either hang in the housing or turn internally. You want to be real careful working on/with that mag as it is worth almost as much as the entire engine�If you take it apart look for signs of the armature end plates rubbing the inside of the housing & look for cracks & splits at the armature end plate screw holes [common problem on those Deere mags]..
~Any other questions just post back�If you need any other info just post back or E-Mail. I have serial number info, settings etc. if you need them�.
[email protected]
Clooney (more)
10-16-2003 04:00:13
 Re: Re: J.D. stationary horse and half model E in reply to Clooney , 10-16-2003 03:53:07
I should have mentioned in my first post.. A good way to test that mag is to pull it out of the engine, then lightly clamp it in a bench vise, then clean the mag drive gear of oil & grease, then spin the mag in the running direction while lightly holding the bare end of the ignitor wire against the mag gear teeth. If you get a nice spattering of spark as that ignitor wire jumps on the mag gear teeth while turning the mag, your mag is probably �good to go���
Jake
10-15-2003 20:34:45
Did you time the magneto correctly? If not, you must.
Also... a common problem with those magnetos is the shaft spinning loose in the armature flange inside the magneto. If it does that it will never stay in time.
There used to be reproduction armature shafts available but I have no clue who supplies them today.
I forget the timing procedure since I have not done it in 20 years. Someone here can help if I can't remember how. It has something to do with those buttons on the end of the magneto cap, one for left hand rotation, the other for right hand rotation.
farmie 46
10-16-2003 19:33:07
 Re: Re: J.D. stationary horse and half model E in reply to Jake, 10-15-2003 20:34:45
The armature must have come loose as with the volt meter peak voltage is almost a half turn past. May have had somthing to do with it setting so many years I guess. I have ordered a book so will look into this further when I get a chance. Thanks Farmie46
