3020 D. 6600 COMBINE motor'S
Larry806
12-02-2003 18:52:42
I have a 6600 diesel combine I don't know what motor it is. It is not the 404 By any chance would it be the same as a 3020 tractor motor I know where a blown 3020 is I could buy cheap & I'm parting the combine
Paul
12-03-2003 10:25:56
 Re: 3020 D. 6600 COMBINE motor'S in reply to Larry806, 12-02-2003 18:52:42
I'm looking for a 3020 crank shaft or a complete 3020 engine if possible. Please reply.
Jon Ruch
12-03-2003 13:31:53
 Re: Re: 3020 D. 6600 COMBINE motor'S in reply to Paul , 12-03-2003 10:25:56
Paul,
I have a 3010 Diesel tractor that I bought. It was overhauled, the paint was not burnt off the manifold, it was sitting. The exhaust was left uncovered and it had a cracked 4th sleeve. Put a new sleeve in it and new rings in all the other cylinders, ground the valves and started the tractor but the PTO knocks. I am not fixing it anymore. The tractor is narrow front, fenders, 3 pt with 3rd link. Tractor is a 6 out of a 10 scale. tires are not very good. Call if you are interested in entire tractor or just the engine. The engine runs great and drives nice but the shifting is sloppy and pto is out.
507-546-3308 Jon
terry clubb
12-03-2003 04:15:31
larry806 the 329 engine was used in the 4030&2840 tractors.
G-MAN
12-02-2003 19:01:23
No, it would by no chance be the same. The 3020 engine is a four-cylinder, gas or diesel, and the 6600 uses a six-cylinder, gas or diesel. Your 6600 probably has a 6329 in it, if I remember correctly.
Tyler-MO
12-02-2003 21:30:06
 Re: Re: 3020 D. 6600 COMBINE motor'S in reply to G-MAN, 12-02-2003 19:01:23
I'm not sure about the 6600 engines...but there are several 4020's running out there with diesel engines out of 4400 combines. Not exactly a match but it works out just fine...a more economical alternative when disaster strikes....I do know that many people have used diesel engines from 6600 7700 and 8800 for irrigaion pump motors or just power units. Good luck Tyler
Larry806
12-02-2003 19:05:48
Thank you very much I guess I should have known that about the no of cylanders. Do you know if it will work in any tractors? Larry
Newgen
12-03-2003 09:19:51
 Re: Re: Re: 3020 D. 6600 COMBINE motor'S in reply to Larry806, 12-02-2003 19:05:48
The 6329 was used in the 4030 and I think maybe the 2940-also in a some of the industrial equipment.
