Foot brakes (turning) why not on a D
Lee V.
01-16-2002 20:22:02
does anyone know why some of the JD tractors i.e. the "D" and the "AR" didn't come with turning brakes that the other models did. Is this safe enough to load and unload on a trailer ? and to drive around hilly country. I'm still thinking of getting a "D" and want to be able to take my grandkids for rides, but I live in mountainous country with a steep drive.. Thanks Lee
George S. in the real NY
01-17-2002 17:35:23
 Re: Foot brakes (turning) why not on a D in reply to Lee V., 01-16-2002 20:22:02
Lee, Given your planned use and terrain, I would suggest that you get something, anything else but the D. For starters, do you know how much a styled D weighs? Mine was around 6600 lbs with about 30 gal of CaCl solution between the two rear tires. I moved mine once on a 2 axle trailer with a pickup pulling it and said big truck next time, thank you. Also, you will know what the platform is for as to get it turned quickly, you have to stand to get enough leverage to turn the wheel. Brakes, the transmission single brake is real feeble and I have no knowledge of how good the individual wheel brakes are. Just cause they are there doesn't make them good brakes. Also, for them to be useful for turning, you have to get the steering sorta aimed into the turn, which brings you back to the afore mentioned issue. And, at 6500#, you gotta be careful on slopes and hills. The rest of the story. The D was made for large long flat fields, like from north Texas to Sask. and parts of Cal and Wash. You know, where you start out in the morning, go to the other side of the field, have lunch there and come back in time for supper. I've used my D discing a 6 acre field and it gets tiring real fast doing all that steering. If it had power steering, well, that would have been a great improvement, maybe even enough to have kept it in production longer. As a recommendation, try a late styled AR or 60 low seat. You can get pwr steer and the brakes are better. Best bet, try one first.
Lee V.
01-17-2002 18:59:19
 Re: Re: Foot brakes (turning) why not on a D in reply to George S. in the real NY, 01-17-2002 17:35:23
Thanks for the great reply..I am trying to decide on an AO (unstyled) for sale right now.. I sure wasn't aware that the D's were that heavy and I am going to have to haul with my Suburban..Thanks again Lee..
Bozo
01-17-2002 16:37:19
Turning brakes were an option on at least the later models of the D. Mine has the parking brake only, which was standard for belt work. The unstyled AR was available with turning brakes by ordering an AO with a vertical stack. In steep terrain chose a gear an leave it there. One of the neighbors was taking a short cut from the ridge to the valley and decided to shift down, never got it into second gear, but stayed with it until just before it flipped and broke in two. Required several new studs, but it was back sawing lumber a week later.
Mark in MD
01-17-2002 14:13:33
There are D tractors available with turning brakes, not that they help alot, these tractors take up alot of area to turn around.
Spoker
01-17-2002 15:15:52
 Re: Re: Foot brakes (turning) why not on a D in reply to Mark in MD, 01-17-2002 14:13:33
There are also some AR with turning brakes. Very few D came out with turning brakes. As they are hard to find.
Mark in Md.
01-17-2002 16:13:43
 Re: Re: Re: Foot brakes (turning) why not on a D in reply to Spoker, 01-17-2002 15:15:52
Deeres of Yesteryear has one for sale on their site, doesn,t look too bad, maybe a little pricey though.
