J.R.: I'm a pony guy, and if you want to get that little engine running, there are several on this board who can help you along. First, does it have any mechanical problems, is it limited to gas and spark (pretty typical)? Did it ever run while you owned it, or has it been DOA? If it's solid, and just not running, it's probably going to cost you less money by far to fix the pony than to buy a new battery box, large batteries, a big generator, starter, fat cables, etc. Just because they have not been running doesn't necessarily mean that they have to be overhauled. I went through my pony last year, and it didn't need any rods or pistons, just rings ($45), valve grind ($40) and gaskets ($70). Also reworked the transmission ($100) for it, new distributor parts ($165) and carb kit ($15), and then miscelaneous seals, plugs, etc. I'd guess I had around $500 in everything, but it had been abused and had sat ourside not operating for years. Now it starts right up with no smoke, and will turn the newly overhauled diesel at 200 rpm for as long as you keep the gas on. REALLY a plus in a cold climate! If you mean to tune it up the first time in a long time, and if it needs coils as well, you can either buy a complete new distributor for it, or a do-it-yourself distributor kit (points, wires, coils, condensers) for a little less. A set of coils alone is $110, so you can get yourself a complete DIY kit for around $165. The carburator gasket kit if needed, is still available through Deere, and is under $20. You say it spins freely, so you must have good power to the starter. Do you have power to the distributor lead with the switch on? Do you have power to the lead from the starter to the distributor while the pony is cranking? Do you have power at both sets of breaker points? How do the plugs look? You'd be surprised how many won't start or run well just because of poor plugs. Post back some of your findings and some one here will help you get it running right. Frank-in-Tallahassee 70D // 855 // VAC [email protected]
