M only turns right
Bama Binder
01-14-2002 19:54:30
Next M FUBAR...I was out giving 4th gear a workout and when I went to turn around (left turn) I got half way through the turn and the steering gave way. The wheel would keep going but the tires gravitated to center and I straightened out. It still turns right.
Whats wrong???
---===] jer [===---
01-14-2002 20:46:20
 Re: M only turns right in reply to Bama Binder, 01-14-2002 19:54:30
Bama Binder, the firsat place I would look is under the hood at the set screw on the steering shaft where the shaft goes into the steering housing. My guess is that it is either loose or gone completely. The one on my M was when I got it and it would catch so as to turn right but slipped for the left turns. It is a set screw that has to be turned all the way in. It drives along side a flat on the stub shaft from the steering sector, if my memory serves me. Try that first.
Good luck. ---===] jer [===---
Bama Binder - Thanks!!
01-15-2002 06:29:27
 Re: Re: M only turns right in reply to ---===] jer [===---, 01-14-2002 20:46:20
I'll check it first thing!! Sounds exactly like what is going on with mine. Thanks again...BB
