4230 3 point
Bowd
01-14-2002 19:54:22
My 3 point bleeds down when I try to box blade wont stay a right level only all the way up are down. Please anyone one know if I can fix it myself . Thanks for any info.
John in Md.
01-15-2002 09:37:30
 Re: 4230 3 point in reply to Bowd, 01-14-2002 19:54:22
You may want to check load selector setting located on lower portion of console.Place selector on bottom setting,if this doesn't work you may have to adjust load control arm extension through plug in transmision housing right side of top link mount.If there is excessive play this can cause three point to bleed down.Hope this helped
Thurlow
01-14-2002 21:27:09
Is your load and depth control set on "depth setting", i.e. all the way down?
