JD420 U
S Putnam
01-14-2002 18:43:56
My tractor RPM surges at all throttle settings other than full throttle. Is this normal?
Tony
01-15-2002 10:43:44
 Re: JD420 U in reply to S Putnam, 01-14-2002 18:43:56
First off, if you haven't, Adjust your 'power screw' or high speed screw a little at a time, first out by 1/2 a turn. Continue until engine smoothes out. If not, of course turn in. More than likely it will shut the engine off. If neither of previous works carburetor must be rebuilt. Very, Very Simple carb to work on.
If confident, that its not the carb, check the govenor adjustment. First get new springs and replace all rod/linkage ends that are worn out. Most of the time loose control linkages only increase the problem.
Last but not least. On most if not all govenors there is a thing called a bump screw. It removes the HUNTING/SURGING out of the engine. In your manual it will tell you where it is and how to adjust.
MERRILL
01-14-2002 19:28:22
WHAT DO YOU MEAN BY A SURGE 10,20,30,40,50+ RPM? THAY NEVER MAINTAIN A CONSTANCE RPM THAY TEND TO VERY A LITTLE ESPECIALY WHEN COLD. I WOULD INSURE EVERYTHING IS SET PER THE MANUAL, MAKE SURE YOU GOT GOOD GAS. MERRILL
