Clooney-70 power steering still turns left
GORDON
12-02-2003 16:53:28
I did as you advised, when I tapped the valve to the rear, the steering stayed centered but could not turn to the left. I tried to turn flow control to ease problem but it did not help. Seemed like when I tapped valve forward again I could turn wheel. It would free up steering but also turn to left. You said that maybe I would have to go into gear box more. What should I do next? Thanks.
Clooney
12-02-2003 17:38:14
 Re: Clooney-70 power steering still turns left in reply to GORDON, 12-02-2003 16:53:28
GORDON, you are going to have to start by setting the worm end play [early steering], or both a worm & sleeve end play adjustment [late steering], then probably doing a steering vane by-pass test.. [those are just the preliminaries to get them out of the way], your real problem is probably deeper in the gear.
~There is pretty good chance that you have a worn helix screw tip [early steering] or a worn hardened sleeve pin or sleeve slot inside the steering gear [late steering]. Maybe even a worn spot in the cam slot..
~Your 70 should have the early steering assembly but a lot of those early units were up dated to the later units.
~This is going to be a hard thing to talk you through by writing on a tractor board..
~My suggestion would be to get the Deere Power-Steering repair manual or at the very least an I & T manual & read up on identifying your steering system & how to adjust it. Then post back or E-Mail with questions.. I would have to write a book to talk you through the steering adjustment & repair,, you really do need a book with pictures & how-to's..
~That system is very difficult to explain but becomes quite easy once you understand how it works..
~Let me know how familiar you are with the Deere Power Steering system & it's basic adjustments & we'll go from there..
~You probably have the early steering [no removable plug on the front worm bearing cover].. If that's the case you might start with a worm end play adjustment..to do that remove the front worm bearing cover & add or remove shims until you get the worm end play to about .002"-.004" end play.
~Next do a helix screw adjustment [you might have to pull the helix set screw out & grind a new point on it as a worn point is a common problem]....To set that set screw end play, mount a dial indicator on the rear of the actuating sleeve,, then remove the helix set screw plug, then turn the screw in or out until you get about .001"-.002" actuating sleeve end play...[you will probably have to grind a screw driver blade to be a proper fit in the set screw slot]
~If you understand & can do the above I will have no problem talking you through all the set-ups & checks..If you don't understand the above you really need a manual before you begin...
~I just got down to your E-Mail today & was going to answer it tonight,, sorry for the delay but I am still WAY behind on my E-Mail replies. I try to follow up on the E-Mails from the B boards first then get to the others when I get a chance...
~Let me know how familiar you feel with your steering system we'll go from there...
[email protected]
