B governor assembly, disassemble
Fred Wilke
01-14-2002 18:09:35
Does anyone know how to get the governor apart to replace the inside bearings. I see 1 snap ring agains the gear but can't move the gear to get the ring off. Does it take a lot of tonage to press apart or is there a simple solution. Any advise would be appreciated. Oh yes, it is off the tractor and on the bench. Thanks Fred Wilke
Gman
01-15-2002 17:49:09
 Re: B governor assembly, disassemble in reply to Fred Wilke, 01-14-2002 18:09:35
Fred are you talking about the bearingon the mag. side under the spring,that would be the only reason to remove the snap ring,and it's a booger to press off I have bent a shaft or two replacing the bearing.You need to pull the mag drive off then press gear and bearing off,because they are both keyed on to shaft. Gman
Deere Puller
01-15-2002 05:55:12
I believe that you're trying to replace the fly bearing on the slide sleeve - The easiest way to do this is to press the drive gear from the shaft (bearing race for shaft bearing will also come off - Be very careful to support the gear square and close to the shaft as it does take quite a bit of pressure), then you can 'operate' on the fly bearing. The snap ring can be tough - you will need a good set of external ring pliers (the type that actually look like pliers - the adaptable tools aren't strong enough for this operation) to remove the ring. Deere uses these rings elsewhere, so the money won't be spent in vain - I bought a set of Craftsman ones for $19. If the sleeve is worn, or the new bearing won't stay on the collar firmly, replace the sleeve while the unit is apart. Don't be afraid to drill & re-pin the weights, either, as tighter pin-to-gear-to-weight will give better throttle response.
Deere Puller
01-15-2002 05:29:16
Gene Davis
01-15-2002 02:54:39
Be sure you take the mag. off BEFORE you try to put the cover back on the opposite end, you can BREAK a mag. housing if it doesen't line when you tighten the bolts up!! LGD
Burl
01-17-2002 10:27:39
 Re: Re: B governor assembly, disassemble in reply to Gene Davis, 01-15-2002 02:54:39
Been there, done that!! Lucky my mag needed rebuilding anyway. Chalked it up to experience, and bought a new one.
Rod
01-14-2002 18:42:46
would a breakdown from a parts book help?
