John Deere Pistons
Rod Trachta
01-14-2002 12:41:13
Can a block for a model "D" that has a 6 1/2" bore be bored out to 6 3/4"?
Gman
01-15-2002 18:00:12
 Re: John Deere Pistons in reply to Rod Trachta, 01-14-2002 12:41:13
Rod that's .250 and a whole lot of meat,I'd be a little scared of it,I don't know why you would want to bore this big.If you want cubic inches stroke the crank a little get a lot more cubes,and watch the old girl come alive. Also what you are going to do with the tractor,.250 bore job and a radical stroke will prhibit the corn patch chores,just show and go. Gman
Rod
01-15-2002 20:24:41
 Re: Re: John Deere Pistons in reply to Gman, 01-15-2002 18:00:12
The tractor I have is a 1927. The origional bore was 6 1/2" but at one time someone switched the block with a replacement. The block has a 6 3/4" bore. The block was cracked so I purchased an orgional with a 6 1/2" bore but I don't have the pistons. The pistons from the 6 3/4" are in good shape so I was trying to reuse them.
