JD-1010 crawler won't start!
Bigtime
01-14-2002 07:44:11
I have a 1010 crawler, 12volt, positive ground, gas, that seems to have had electrical charging and starting problems since I bought it. It ran well and even started occasionally without help. After a new starter, new voltage regulator, and resetting the brushes in the generator, still am having problems. As I pulled the lead off the coil 1/4" there was spark that made it kick over, so I repalaced the coil. In removing the old coil, I noticed the (-) coil pole was wired to the distributor and the (+) pole to the ignition. There was no in-line resistor. The old coil writing said "use with external resistor only".
My new coil is a 12V (internal?) resistor that I wired the (+) pole to the distributor as the wiring diagram indicates. Didn't start or pop. Reversed the wires on the coil (like previously installed) and still didn't start so I changed them back. Pulled center lead 1/4" off distibutor and got spark and a few pops but not enough to start it. Anyone have any ideas or simple tests whats wrong or what to try next?
Greg
01-20-2002 18:25:47
 Re: JD-1010 crawler won't start! in reply to Bigtime, 01-14-2002 07:44:11
My service manual says the distributor wire goes to the + terminal on the coil. I have 2 1010's. The 61 is positive ground (correct) and the 62 is negative ground (incorrect I believe). One was driving me crazy with sputtering intermittently. After a full tune up and carb rebuild, which it needed anyway, it still sputtered once in a while. Yesterday I noticed the fuse wire hot, very hot. I pulled the fuse holder top off to find a VERY hot hunk of metal (very rusty) in place of the fuse. After cleaning the connections and putting in a proper 20amp fuse, ignition problem, sputtering, stopped. COOL!!! This has driven me nuts for months. I checked my other 1010 and someone had put tin foil in place of the fuse. After a few curses, I replace that also. 5 fuses cost me $1.25 at Napa. Why do people do this BS? Good luck with yours. Greg
Tom in Mo.
01-14-2002 15:50:50
You didn't say whether you tuned it; sparkplugs, points, condenser, dist.cap, timing set, etc.
Bigtime
01-15-2002 06:42:51
 Re: Re: JD-1010 crawler won't start! in reply to Tom in Mo., 01-14-2002 15:50:50
It was working fine last time I shut it down, but thats where I was headed next - the distributor. Points, plugs, wires and cap looked fine visually though.
