JD 3010 Wheels
Tim Crist
01-13-2002 19:22:01
Does anybody know if 3010 wheels will fit a 70?
I need to loose the weight of the cast and want ot put pressed steel on. Thought it might be easier to find some from a 3010.
Thanks
Mike Aylward
01-14-2002 06:21:35
 Re: JD 3010 Wheels in reply to Tim Crist, 01-13-2002 19:22:01
Tim, the 3010 and 70 both have 3 1/8" axles. If you are wanting to lose weight on your 70 find a set of 9-bolt dual hubs and put on the pressed steel wheels. They will fit right on your 70 and you will lose a bunch of weight. Hope this helps. Mike
