Jd 3010 wont stay in reverse
joshua
01-13-2002 17:15:35
i have a 3010 and just rebuilt the top shaft of the trans. i put in new syncronizers and spacers in each of the clusters. i put the tractor back together and now it wont stay in reverse. i was wondering if they didnt give me enough parts or not, could you tell me how many sycronizers and spacers go in each of the clusters. and what else might be the problem
Zig
01-13-2002 19:09:11
 Re: jd 3010 wont stay in reverse in reply to joshua, 01-13-2002 17:15:35
Joshua, Did you adjust all the end play out of the shifter shafts and use new detents?
joshua
01-14-2002 09:35:48
 Re: Re: jd 3010 wont stay in reverse in reply to Zig, 01-13-2002 19:09:11
what is a detent
Zig
01-14-2002 17:06:11
 Re: Re: Re: jd 3010 wont stay in reverse in reply to joshua, 01-14-2002 09:35:48
Joshua, The detents are the spring loaded points that ride on the shifter cams. The points wear off of the old ones and they get sloppy and loose positioning of the shift lever. The new ones will be a ball bearing resting in a socket. On the right side of the trans case you will find 2 plugs, be careful when you take them out because they are spring loaded.
