John Deere 2 cylinder crawler
Paul Stanley
01-13-2002 15:59:28
I have a neighbor with a small crawler. It is two cylinder. It has the number 610 or 620 on the side. It was in the salmon berries so I'll go back another day for the serial number. There is a plate on the engine, but right now it is hard to get there. I was wondering though if the model number seems correct. It was clearly visible, but my memory is bad. It was 610 or 620 for sure though. Any pics or info would help. He ran when he parked it, but water in the oil. He is looking for a new engine. Any leads?
440Sam
01-13-2002 19:37:40
 Re: John Deere 2 cylinder crawler in reply to Paul Stanley, 01-13-2002 15:59:28
Paul:
If it was a 2 cylinder 440 and was origional the number on the blade should be either "63", "64" or "602". The 430 was fitted with a"62" or "602" blade. The "610" blade was fitted to a 1010 (4-cylinder) crawler.
Hope this helps, Sam
Paul Stanley
01-13-2002 21:37:04
 Re: Re: John Deere 2 cylinder crawler in reply to 440Sam, 01-13-2002 19:37:40
Okay, thanks again. I'm going to hack down tht brush next week to get the serial number and a better look.
Brandon
01-13-2002 17:39:55
The number you saw was most likely the loader model number--620. Since it was a two cylinder, the crawler was most likely a John Deere 440. Take a look at my website below, you can find pictures there of various 440s-see if it looks similar.
If not a 440, it could possibly be a 430 or 420. There are links at the website that can show you pictures of these tractors as well.
If it is a gasoline engine, the engines should interchange between the three tractors.
If it is a diesel, you could get one from a 435.
Good luck,
Brandon
Paul Stanley
01-13-2002 19:08:58
 Re: Re: John Deere 2 cylinder crawler in reply to Brandon, 01-13-2002 17:39:55
Thanks Brandon. That was just what I was looking for. He did mention he thought it might be a 440, but wasn't sure where he came up with the number.
charles ethridge reply to brandon
01-14-2002 17:34:54
 Re: Re: Re: John Deere 2 cylinder crawler in reply to Paul Stanley, 01-13-2002 19:08:58
paul, i am taking apart a 440ic now and brandon has been a great help, his 440 site is really nice, if you want i will send pic of mine to you so you can see what you may be in for if you decide to restore the crawler, also thanks for your help brandon. charles
