J.D.4000 brakes
Gman
01-12-2002 19:14:19
My John Deere 4000 brakes don't feel up to snuff,you just touch them and you got brakes big time. I don't hear any rackett or haven't found any shavings indicating brakes are going out. Is there anyway to check the wet brake set up to see if the brakes need to be rebuilt.Any ideas would be welcome thanks Gman (Garland)
ET
01-13-2002 17:14:51
 Re: J.D.4000 brakes in reply to Gman, 01-12-2002 19:14:19
If the linings are coming off they will be in the hyd. suction screen. You have to drain the transmission oil to get it out. The plug is to the rear of the hyd. filter. The square of your
half inch ratchet loosens the plug.
Red Man
01-13-2002 15:22:37
Only way to check brakes is to remove an axle housing and visually inspect them.
mrm
01-13-2002 13:16:38
Are you useing JD hygard oil? Also I would try bleeding the brakes,it can't hurt.
Gman
01-15-2002 17:35:12
 Re: Re: J.D.4000 brakes in reply to mrm, 01-13-2002 13:16:38
Thanks fellows for the comeback,this 4000 is a little modern,I'm use too working on these old two cylinders. When I purchased the tractor it had a red type hydraulic fluid it took two flushes of J.D. Hygard to get that garbage out,lift worked 100% better but brakes were still awful sinitivy (spelling stinks)I'll check the screen and see if there's any trash on it. thanks again. Gman
