Gas cap
R. Franklin
01-12-2002 18:10:42
I have a JD 60. It is a great tractor! However, I am having a problem keeping the gas cap from sealing well. It constantly leaks fuel on my fresh paint. I have even bought a new cap thinking it must be something I can't see! No,that didn't even work, it still leaks. Any ideas?
mrm
01-13-2002 13:37:25
 Re: Gas cap in reply to R. Franklin, 01-12-2002 18:10:42
I had same problem on my 720 diesel when I restored it back in 1985 JD only sells cap that is vented for later tractors.I solved my problem
by first makeing sure the tank vent tube is open
,mine had just had new tube installed,then I epoxyed the vent hole on the underside of the cap
shut. ---caution--- make sure your tank is vented
out the proper place I can't stress this enough!!
Sam
01-12-2002 21:13:12
I don't know the solution to this problem, but would like to offer my sympathy. This problem must be pretty common. My 60 leaks major gas at the cap and I know another guy whose 60 does this. Filling to only half full won't help because the leak, at least with my tractor, is the result of pressure building up in the tank.
steve II JD4000
01-12-2002 20:30:00
keep it half full not over full.
Clooney
01-12-2002 18:53:55
~R. Franklin, make sure you aren't using an early vented fuel cap on a late vented fuel tank.
~I the cap is correct for your fuel tank make sure the neck isn't leaking where it is soldered to the tank.
~If the tank is the late vented tank check the vent for rust or mud dobber dirt plugging the vent.
~Make sure the top of the filler neck isn't bent or distorted.
Bman
01-12-2002 18:15:01
PUT ANOUTHER RUBER GASKET UNDER IT
