320 J D
David
01-12-2002 15:05:06
Have a 320 JD that has lost the serial tag. Can I get a replacement tag from a JD dealer,What numbers and where are they located on the tractor would I need to have this done. Thanks for any help David
Tugboat
01-12-2002 18:26:14
 Re: 320 J D in reply to David, 01-12-2002 15:05:06
David; I'm told that if you take it to your local JD dealer they can provide you with a replacement tag and rivets. I'm working on a 320 now and recently found a number stamped on the transmision housing. I don't know it this relates to the tractor S/N or not. Please let me know how this works out. I have a bunch of these tractors.
Tugboat
Ray
01-13-2002 16:47:35
 Re: Re: 320 J D in reply to Tugboat, 01-12-2002 18:26:14
The block number under the generator is what you
need to get a tag.This number can be traced by
deere and tell you the serial number of the
tractor it was sold with.If the block has been
changed you still won't get the correct number.
