JD B Spark Plug Adapters
Craig Noble
01-12-2002 07:47:22
I am restoring a 1941 JD B and have always had problems with spark plugs, i want to install spark plug adapters so i can run a hotter plug but i do not know what exact plugs i will need to get. Any help or insight would be greatly appreciated. Thanks Craig
Roy
01-12-2002 18:04:19
 Re: JD B Spark Plug Adapters in reply to Craig Noble, 01-12-2002 07:47:22
I use DENSO L14-U in my styled John Deeres and do not have a problem with fouling.
Chuck
01-12-2002 08:51:15
can't see what adapters would do for you situation. I'd recommend a mag rebuild to get the spark hotter....
Paul from MI
01-12-2002 08:21:58
Craig,
I tried them in my A & B, without much success as far as fouling. I just couldn't seem to find a hot enough plug to work good. If you were working your tractor all the time they would be fine. Cost per plug is lower, and if you find a hot enough plug to put in the adapter, they would work OK. Meantime, I went back to Autolite 388's.
Paul
