Mark A
01-11-2002 13:03:57
Re: Help Finding Right Tractor in reply to Little PAUL, 01-11-2002 12:12:47
A JD 40S, which is a smaller "standard" tractor, and is similar to a "M" would be nice, as it has a nice 3 pt hitch for a shredder. A "M" is ok, but am not sure if it has a 3 pt hitch. A JD 1020 is a little bigger, and newer, tractor and is not a 2 cylinder Johnny Popper. These are all older tractors with a wide front end, "M" and "40S" in the '40s and '50s, 1020 in the '60s. Parts should be available fairly easily for most of these. There are newer JD tractors made in the '70s and '80s, but I dont know all the numbers. I think there is a '80s model JD 630, 3 cylinder diesel (possibly made by Yanmar), that appears to be about the size of a 40S or your current Allis B, but I dont know that much about it. Maybe some of the other fellas (or gals) can explain more. Check your local papers for tractors for sale, and if you have access to the little classified papers, such as thriftynickel or greensheets, check there also. You can always repost a message here to get advice on what you found. Lets help this guy out, and not start any color wars again.
