Wayne, I have 40 and 420/430 generic wiring diagrams, and will try to identify some of the wire/colors and list what I would use, but will still make my answer fairly generic which would work on most any similar circuits. I listed this before and strongly noted my own personal preference in some instances may be a slight over kill or over engineered, because I use a 12 Gauge in many places that a 14 was originally used or would suffice just fine. Still, the larger the wire the less voltage drop and I squared R energy loss, but especially in 6 volt systems, I like to err on the conservative and voltage saving side (EVEN if negligible) by the use of 12 Gauge over 14 on the main load and ignition circuits. (A) On the 40 Series, I would use 12 Gauge: 1) The hot main feed red wire from the starter motor to the ammeter. 2) The black wire from the ammeter to the Voltage Regulators BAT terminal. 3) The black wire from the Generators ARM post to the ARM/GEN terminal on the Voltage Regulator. 4) The black/white tracer from LOAD on the Voltage Regulator to and through any fuse, to the BAT terminal on the ignition switch. 5) Especially on a 6 volt tractor, although it was probably a 14 and 14 would work, I prefer a 12 Gauge blue wire from the IGN output on the Ignition switch down to the coil. 6) I prefer 12 to the cigarette lighter. I would use 14 gauge all other places like to lights and the generators Field etc. GENERIC ANSWER: I prefer 12 Gauge (even if overkill) on circuits that are main current load feeders, like from the starter to the ammeter(where all non starting power goes into or out of the battery),,,,, ,,,,, ,,,, Basically on the Voltage Regulator, its 12 Gauge to and from the BAT and ARM and LOAD terminals, but 14 on the FIELD terminal, and 12 to the BAT terminal on the ignition switch. (B) On the 420/430 I would use 12 Gauge: 1) The main hot red feed wire from the starter post to the ammeter. 2) The black wire from the ammeter to the BAT terminal on the Voltage Regulator. 3) The black wire from the VR's LOAD terminal, to and through any fuse, to and through any key switch, to the BAT terminal on the ignition switch. 4) The black wire from the ARM terminal on the VR to the ARM post on the Generator. 5) The black wire to the cigarette lighter. 6) The blue wire from the IGN on the ignition switch down to the coil. AGAIN, Basically on the Voltage Regulator, its 12 Gauge to and from the BAT amd ARM and LOAD terminals, but 14 on the FIELD terminal. 12 Gauge on the main hot feed wire from the starter to ammeter, and on the coils feed from the IGN terminal on the ignition switch, 12 to cigarette lighter, and then 14 gauge elsewhere. USE 00 GAUGE BATTERY AND GROUND CABLES ON 6 VOLT TRACTORS FOR BEST PERFORMANCE. Is that what you were lookign for Wayne?? I use 12 on charging and main feeds and 14 elsewhere like lights and generators field, even if some were 14 original. Do you need me to e mail you a copy of the 2 wiring diagrams I have????? ? If so let me know, [email protected] Good Luck, God Bless yall John T Nordhoff
