Re: 1010RS Gas won’t run
hotflashjr
01-23-2019 10:25:32
Forgot to put that. Saturday I had gotten the tractor ready for the storm. Buffed the points with a dollar until nice and clean and put in new plugs. Made sure the points were set at .022 and plugs at .025 as owners manual says. They were still clean and shiny on Sunday when this happened. I guess it’s worth a try cleaning them again. I’ve got another set of points on hand that are new I can try as well.
old
01-23-2019 12:12:30
 Re: 1010RS Gas won’t run in reply to hotflashjr, 01-23-2019 10:25:32
Many times a dollar bill just isn't good enough you need a REAL point file to do the job.
Mike M
01-23-2019 11:09:07
I fought dirty / corroded points on my generator set last time I ran it. With cap off I could work points by hand opening them and get spark from coil wire. Put it all back together and no spark ! I finally got more aggressive with the points and that got good spark all the time. I need new points but didn't put them in yet. Sounds like you may have this issue too.
hotflashjr
01-23-2019 11:11:05
 Re: 1010RS Gas won’t run in reply to Mike M, 01-23-2019 11:09:07
With all the moisture this summer almost every time I went to run this tractor or our Cub I had to polish points or use a point file on them.
