Is this REALLY a '47 A?
M.B.
01-09-2002 19:27:46
After reading the responses from "STumped-'47 A won't start" below I am confused about my '47? A. Serial # is 578955. Has slant dash, all fuel, shutters, electric start on top of flywheel, battery is behind the fuel tanks- not under the seat, engine rails 'appear' to be cast and are the same width front to back, rear wheel centers are cast, 6 speed- Hi/Lo. The serial # listing on this site and a friend's tractor book both list it as a '47. Is it "really" a '47 or a mutant painted green? Thanks in advance for any info!
Thanks!
01-10-2002 16:54:31
 Re: Is this REALLY a '47 A? in reply to M.B., 01-09-2002 19:27:46
Haven't been on this board long enough to know there had been a discussion about this before. Don't think it's a mutant now;-) Thanks again for the responses, I appreciate the help!
mrm
01-10-2002 15:35:43
I'm glad we know what type of "A" it is now,but
what really matters to me most is a tractor that
runs properly! So did you get it to run yet?????
Fred-CT
01-09-2002 20:51:44
M.B. I have #578719 and have been through this before on this board. My understanding is that the "new and improved" late styled A began production sometime in March of 47. Our tractors were produced before the change in 47 but are considdered "early" styled 46 Model A's. Guys out there - correct me if I am wrong? Good luck!! FSB
Will P
01-09-2002 21:24:32
 Re: Re: Is this REALLY a '47 A? in reply to Fred-CT, 01-09-2002 20:51:44
Early styled 47 is what you have. The 47 model year is broke up by the early and late. The change came in the middle of the year.
Will P
Todd - you are correct Will P
01-10-2002 06:01:41
 Re: Re: Re: Is this REALLY a '47 A? in reply to Will P, 01-09-2002 21:24:32
Stan - Florida
01-10-2002 04:44:07
Will P,
You're absolutely right. The '47 Model year started at 569610 and the switch to the pressed steel frame, battery-under-the-seat, etc. was made at 584000 on 3/31/47.
Stan
Will P
01-09-2002 20:21:04
Yes its a 1947
Will P
