1946b flywheel endplay
Bob P.
12-02-2003 08:52:11
I have a 1946 B with electric start. I notice the edge of the flywheel teeth are wearing.
I leaned into the flywheel and I noticed I can shift it 1/4+" s towards the clutch or otherside of engine.
How much play is normal and how to you adjust it?
Also I know where a flywheel in good condition is, but it is for a 1950-1951 B will It work is it balanced and same, diameter etc...
Thanks
Bob P.
[email protected]
Clooney
12-02-2003 09:15:29
 Re: 1946b flywheel endplay in reply to Bob P., 12-02-2003 08:52:11
Bob, since you have a few questions lets take them one at a time....
~You ask..... ..... ..... .....
>>I leaned into the flywheel and I noticed I can shift it 1/4+" towards the clutch or otherside of engine..... ..>> That's too much, you need about .005" to .010".. A human hair is about .003"...
>>How much play is normal and how to you adjust it?..... ..>>See above for normal play...To adjust, first loosen the flywheel pinch bolts, then remove the clutch cover & block the center of the crankshaft to the left, then use a block of wood & big hammer & drive the flywheel on until you have the correct end play..Or just drive it all the way on, then remove the R/H blocking, then rap the crankshaft in the center of the flywheel with a brass drift & hammer until it loosens up to the correct .005"-.010" end play... If you don't have a dial indicator you can set that end play by feel ...005"-.010" is just a very slight movement of the flywheel & is a very light thunk..If you have a pronounced clunk it is still too much.. Once set correctly re-tighten the pinch bolts....
>>Also I know where a flywheel in good condition is, but it is for a 1950-1951 B will It work is it balanced and same, diameter etc.....>> There was a flywheel change in early 1948 so the 1950-1951 won't work....
_____ _____ _____MORE_____ _____ _____ _____ _____ __-
~You can remove your flywheel & heat then remove your ring gear, then re-heat it, flip it over & install it with the bad part of the teeth facing out.. You will then have to take a hand grinder & re-grind the tooth chamfer on the inside of the teeth... Once that ring gear is flipped over it will work for years [there are a lot of those old Deere's done that way & it works good]...
[email protected]
Bob P.
12-02-2003 09:22:58
 Re: Re: 1946b flywheel endplay in reply to Clooney , 12-02-2003 09:15:29
Thanks your the man!!
