Bolting main case to rear axle assembly, '51 B
Kurt_JDB
05-15-2006 19:22:49
I am about ready to bolt my "51 B back together after splitting the main case/rear axle so I could work on the differential and transmission. When I took things apart, all the bolts holding the tractor together were pretty loose. (This certainly explains the oil leak) My questions are:
1. What gasket sealant if any should I use?
2. Should I get new bolts and lockwashers?
3. How tight should the bolts be?
Thanks,
Kurt
John Van Valkenburgh
05-16-2006 18:34:51
 Re: Bolting main case to rear axle assembly, '51 B in reply to Kurt_JDB, 05-15-2006 19:22:49
Kurt,
I've had good luck using plain old "Indian Head" gasket shellac on the large gaskets. I use brake parts cleaner to insure the surfaces are clean and oil-free.
The gasket shellac works well for holding the gasket in place.
John
1953 Model 50
F-I-T
05-16-2006 16:07:59
Kurt:
There a lots of good space-aged adhesives and sealants out there, but I like Permatex. The type that you get in a tube works well for gaskets that large. Cut a spatula from an old laundry detergent bottle or a bleach jug and use that to spread it around. Let it tack up some, then squeegee the gasket in place in place, and then coat the other side of the gasket and then the mating surface. It has always worked weell for me.
I think the factory would have probably used something like "Indian Head" gasket shellac.
Frank
Kurt_JDB
05-16-2006 18:31:42
 Re: Bolting main case to rear axle assembly, '51 B in reply to F-I-T, 05-16-2006 16:07:59
Thanks, Frank. I"ll check it out.
Kurt
JDBert
05-16-2006 12:05:23
I like to use "High tack" in a spray can. You get lucky at that split- there are 2 aligning pins on the axle housing side. I clean everything with brake cleaner let it dry-spray down my gasket on booth sides with high tack and install. I'd get new lock washers, I've found that most of the bolts on a two banger deere are right in between what you can buy new-(usually a 1/4 inch difference). On those bolts you'll probably have to use the orginals because most of the holes have a "bottom" to them. Make sure your gears line up, and if you still have the rearend on make sure you remember to have the PTO shaft in there and lined up as well- DONT FORCE IT together by tighting the bolts up.
Kurt_JDB
05-16-2006 18:40:27
 Re: Bolting main case to rear axle assembly, '51 B in reply to JDBert, 05-16-2006 12:05:23
Thanks for the reply. I have been worrying over the problem of how to line things up. I thought I might get some threaded rod to put in a couple of the bolt holes and gradualy draw the parts together until the pins engage.
Kurt
ET
05-16-2006 05:00:20
I like to glue big gskets like that to one side or the other with automotive weatherstrip adheasive. Over the years I have seen a lot of gaskets like that one that seem to squirt out from between the housing even with all the bolts tight. Glueing them keeps them in place. I would use new lock washers on all the bolts holding it togeather. Any lock washer that is flat or nearly so will not work well. There are standared torque tables available for all hardware regardless of how hard they are. Automotive service manuels have them as well as new generation john deere service manuels. If all the bolts are tightened equaly with a torque wrench the hardware is less likly to loosen and the gasket seal is more even and less likly to seep down the road.
Kurt_JDB
05-16-2006 05:52:38
 Re: Bolting main case to rear axle assembly, '51 B in reply to ET, 05-16-2006 05:00:20
Thanks,
The existing lock washers are almost flat, and some of them are broken. I have found that almost all the bolts and fastners on this tractor are loose. Like a big bag of bolts.
I was thinking or replacing the bolts because I thought they may have gotten stretched over time.
Kurt
ET
05-16-2006 09:30:52
 Re: Bolting main case to rear axle assembly, '51 B in reply to Kurt_JDB, 05-16-2006 05:52:38
All new bolts would be cheap insurance and put your mind at ease.
DSK
05-15-2006 20:14:13
I've had good luck installing these gaskets dry, maybe use just a dab or two of silicone on the top surface to hold gasket in place while joining the two pieces together. The last one of these I installed had the message printed on it, "mating surfaces must be oil free and clean". As for the bolts & washers, I would use the original ones if they look OK. As for torque, the JD service manual does not specify a torque spec, just says tighten securely. You probably can't get at the side ones with a torque wrench anyway.
