Clooney - governor gasket thickness
Ed
12-02-2003 08:08:30
As you know, this gasket,(B2655R) and the the upper water pipe gasket,(B2609R) are no longer available from Deere and I would like to know the (approxamate) thickness to cut them. (Late B) Thanks as always.
Clooney
12-02-2003 08:32:47
 Re: Clooney - governor gasket thickness in reply to Ed, 12-02-2003 08:08:30
Ed, I can't out right answer your question but can tell you how I determine the gasket thickness..
~I first set the governor on the engine with NO gasket under it. Then try to move the mag drive flange within it's play.. If there is any play I rotate the crankshaft to about 10 or so different places & re-try the governor gear play.. If I have play at all crank settings then I don't use a gasket or just use a real thing paper gasket [if no gasket is used I use Loc-Tite 518 as a gasket replacement] .... If I don't have any governor gear play I add a few pieces of gasket material under the governor at all 4 sides [then install a few bolts & tighten] to determine the minimum thickness needed to get a little gear play AT ALL CRANKSHAFT POSITIONS.. CAUTION: the gasket thickness must be set at the gear's tightest position...
~That last tractor I just made a governor gasket for was an A & that I made form .025" gasket material..
~Most of those old 2-cylinder tractors have some crank & governor gear wear so they tend to have a lot of gear backlash & slop.. that causes gear rattle & ignition timing scatter..
~Don't make the gear backlash too tight,, set the gear backlash at the tightest place....
~One more thing USE THE BEST GASKET MATERIAL YOU CAN BUY.. that cheap cardboard gasket material will allow oil to seep through it's cheap laminate & you will always have a wet seam around the governor case...
[email protected]
Ed
12-02-2003 08:47:52
 Re: Re: Clooney - governor gasket thickness in reply to Clooney , 12-02-2003 08:32:47
EXCELLENT information,(as always). Thank you so much for the quick response!
