JD60 stuck break
Leon R
01-08-2002 21:09:44
I just acquired a JD60 that had been sitting for several years with the brakes applied. When we tried to tow it out only one brake released. What are some means of trying to break it loose without dragging it around too much.
Mr. Nobody
01-08-2002 21:13:35
 Re: JD60 stuck break in reply to Leon R, 01-08-2002 21:09:44
Spray some of your favorite penetrant between the brake drum and the brake casting. Next, take a hammer and tap lightly around the brake drum, doing it a number of times. Many times, but not always, this will free the brake.
donwisc
01-09-2002 06:51:35
 Re: Re: JD60 stuck break in reply to Mr. Nobody, 01-08-2002 21:13:35
If the previous post does not work, its not that big a deal to remove the brake assy from the gear case. There are 3 cap screws and a dowel that position the case. once you have it off it is much easier to remove the drum and then clean the internal sliding parts.
After you finish the first one you will probably want to do the other side also. Good luck
