Several Stupid M questions from a not so smart M owner. To start with, it wasn't running when I bought it. It does have good compression so I am down to getting the carb and ignition straightened out. 1. It is a 1948 with an original (4 position I think) light switch. I have been all over that rascal and can't find a cut-out relay or voltage regulator. Does that switch do that function?? 2. If the light switch does do that function, does it need to be polorized like a voltage regulator?? The reason I ask is the previous owner had the battery negative ground. I changed it back and need to know if it needs to be re-polorized. 3. I really need a wiring diagram...anybody got one they can E-mail me or post here?? 4. Any suggestions on which Carb kit to get?? Any special tricks to a MS (I can't spell Marvel Schnabel) Carb?? This is the first MS I have been into but have rebuilt carb off my Farmall Super H and Farmall Cub...I can't imagine anything worse to work on than a Cub carb. 5. What are your spark plug preferences and heat range preferences?? I don't know if it is oil burner or not, but I want to start with a mid range plug for an M until I get everything sorted out. 6. Does JD still have manuals? I need a repair manual and a parts manual. If not JD then who. That should about do it for now. You should have seen me unload the thing...I had to pull it off the trailer with my JD LX178 front wheels off the ground and all...I wish I had a picture. Thanks for now...BB
