JD A the transmission
Steve II
01-08-2002 15:29:26
Want to know if the transmission in JD 44 A tractor, when pulling it with out engine running, will the oil in the transmission start pumping around in the transmission?
P{appy
01-08-2002 19:43:21
 Re: JD A the transmission in reply to Steve II, 01-08-2002 15:29:26
There is no oil pump in the transmission/differential. As the gears turn, they sling oil/grease up and over the other gears. Inside, there are some little troughs that direct oil to the bearings in the sides of the case. Whether running under its own power, or being towed, it works the same.
Joe
01-08-2002 15:53:17
yes, the gears move just the same as when it runs except the 1-6 gears wont move.
Steve II
01-08-2002 17:42:53
 Re: Re: JD A the transmission in reply to Joe, 01-08-2002 15:53:17
does it use oil filter in transmission?
Steve II
01-08-2002 17:37:33
My is a 1-6... when engine is running as pto runs does pump run?... when engine not moving, and you pulling tractor is pump going?
