Clooney,,,,jumpy clutch
Wayne in Tn.
01-08-2002 15:20:29
I took your advice and loaded the tractor and tried slipping the clutch. But first I removed the two cultivator mount bolts on the bell housing, then sprayed a can of PB Blaster into the holes and let it run out the dust cover. LOTS OF IMPROVEMENT !! Now I can start off without snapping my neck. If it just stays this way I won't be breaking it into. Thanks, Wayne.
easydoesit
01-10-2002 13:11:09
 Re: Clooney,,,,jumpy clutch in reply to Wayne in Tn., 01-08-2002 15:20:29
Hey Wayne,
Green magazine has a real good article on jumpy clutch this month.
Wayne
01-10-2002 14:21:02
 Re: Re: Clooney,,,,jumpy clutch in reply to easydoesit, 01-10-2002 13:11:09
Yes, I read the article, but the Dubuque Tractors are a horse of a different color, you have to break them into to see the clutch. Thanks, Wayne.
Clooney
01-08-2002 15:27:36
~Wayne, it sounds like the lining decided to stay attached to the disk & not get rusted to the flywheel. If you get a sudden change in clutch pedal height the lining probably fell off & you will have to "go in".
