P T O SHAFT QUESTION
38 JD A
12-02-2003 07:13:19
I HAVE A 1938 UNSTYLED A WITH THE POWER LIFT AND PTO . MY QUESTION IS THE PTO SHAFT IS SHEARED OFF ON THE END AND 1 OF THE EAR IS MISSING ON THE REAR OF THE HOUSING . WEAR CAN I LOCATE A GOOD USED SHAFT ,HOW MUCH SHOULD I EXPECT TO PAY,WHAT YEARS WILL INTERCHANGE,IS IT POSSIBLE TO PUT THE NEWWER SHAFT IN I WOULD LIKE TO EVENTUALLY USE THE TRACTOR TO DO SOME LIGHT DUTY MOWWING THANKS FOR ANY ADVISE .
I AM LOCATED IN NORTH EAST OHIO
Clooney
12-02-2003 09:28:23
 Re: P T O SHAFT QUESTION in reply to 38 JD A, 12-02-2003 07:13:19
38 JD A, that is a tough question to answer without seeing what you have now....
~Here is the deal [well sort of],,, there were a few different PTO shafts offered on those un-styled A's & to make it worse there were some retro-fit kits available to swap those shafts over to the later standard size spline..
~Seeing as you have the rear housing with an ear [probably for a flipper guard] it sounds like you have a retro-fit shaft..
~What I usually do is take the old shaft with me when looking for a new [used] one & match the front part up to be like the one removed & the rear splines to fit what I need..
~If you want to try to buy a new shaft by phone give me an E-Mail & I will copy the un-styled "A" PTO shaft parts page & E-Mail it to you,,, that way you can see [& try to match] & possibly find out what you need,, then ask for it by part number....
[email protected]
38 JD A
12-02-2003 09:56:59
 Re: Re: P T O SHAFT QUESTION in reply to Clooney , 12-02-2003 09:28:23
I DO HAVE A JOHN DEERE PARTS CATALOUGE FOR THE UNSTYED A BUT HAVENT TRYED TO GET NEW YET BECAUSE I AM AFRAID TO KNOW WHAT THEY WOULD WANT IF IT IS STILL AVAILABLE.THE CURRENT SHAFT IS THE SMALLER SPLINE.
Clooney
12-02-2003 14:14:44
 Re: Re: Re: P T O SHAFT QUESTION in reply to 38 JD A, 12-02-2003 09:56:59
38 JD A, I don't believe you will find a new shaft.. You will have to call around for the later replacement shaft that has the spline size to fit your equipment..
